While moving a light load of dirt, heard a snap/clank, then nothing. No hydraulics to lift/tilt or drive functions. Engine runs, just no hydraulics. It's dead in the field. I'm guessing the gear-pump failed, but only a guess based on reading. Hydraulic level is good, clean fluid, filter was replaced 8 hr's ago on the hr-meter (in March). Any way to check other then pulling the pump? Any advice on pulling the pump, do I need to drain the hydraulic tank or can I attempt to bag / plug the inlet line to stop flow while replacing the pump? What else could it be if it's not the pump (common to all functions). I've only had this thing less than a year, so don't know that much about them yet. It's a 99 6635SXT 2-speed / 80hp. Any advice appreciated. thanks...Scott
