Gehl 5625 skid steer thats out of control!
lkenny
Just took delivery of this unit and first trouble found is that as soon as you start up, the machine wants to take off to the right. T-bar overcompensating to the left will allow awkward forward motion. I have the Shop Manual on the way from Ebay, but prior to it's arrival, any thoughts? Serial # plate is missing where it should be.
My sticker is also missing and could not find any other numbers. You can download the OM from a post I recently answered. Mine has a small amount of movement to the right also during warm up, about one inch per minute. Put on a new front brake cable but it is still doing it. I will be watching your post, good luck!
Got the unit up on blocks and what i see is a slow creep forward or backwarddepending which was the last direction sought. Removed both left and right linkages under the seat to remove any T-bar influence at neutral but still the creep.
Any luck with the creeping? I am anxiously awaiting your result due to mine having a slight creeping also,
So far i have found badly worn bushing, journal and bolt on the lowerpart of the crank on the TANDEM PUMP CONTROLS. So that would be items 3,4,5 on the parts diagram. If i could add a pic here i would. Can't seem to do that. So i am awaiting these parts. I i had an email i would send you a photo. Mines is [email protected].
