Are you referring to hydraulic filters?? What pick up tube?? Ive owned this thing for two weeks. I have replaced fuel filter and it does not use any oil. A guy from an implement dealer suggested a weak spring in the governor, I got into the governor this evening and haven't found anything that I believe out of the ordinary.I have done a lot of research but exploded views don't always help that I'm new to diesel engines.I do and would greatly appreciate any help. One more thing when the engine is revving up if I use a hydraulic function, like the bucket tilt up and hold it there the revving stops.I'd look at the filters and pickup tube first. Is it using oil?
The pickup tube was the one that gets the fuel from the fuel tank.Are you referring to hydraulic filters?? What pick up tube?? Ive owned this thing for two weeks. I have replaced fuel filter and it does not use any oil. A guy from an implement dealer suggested a weak spring in the governor, I got into the governor this evening and haven't found anything that I believe out of the ordinary.I have done a lot of research but exploded views don't always help that I'm new to diesel engines.I do and would greatly appreciate any help. One more thing when the engine is revving up if I use a hydraulic function, like the bucket tilt up and hold it there the revving stops.
