Gehl 3610 Lift Arms
sonny730
I have a Gehl 3610 early 90"s. Had it for years with no problems. Today I was clearing snow from my property, and after maybe a half dozen moves the lift arms will not lower. They raise as they have always, and the tilt arms function fine up and down. It is T-handle control. When I push the bar to lower the lift I can hear the pump engage, but no response. From that I would assume that the solenoid and pump are functioning so I really don't know where to start with it. Any advice or direction on this would be greatly appreciated. THANK YOU.
Hello I had the same problem on my 4610. If you lift the body up and you are looking into the engine compartment there is a little box near the front that has 2 wires that are hooked to it. They are some sort of relay that control the lowering of either the bucket part and the arms. If one is unplugged the bucket or arms will not lower. Sounds like 1 of the wires has come off. Hope this helps.
