gas leak question/help
tardster
Hello everyone, I'm a noob here in the forums and did some searching but couldn't quite find what I need help with. I have a clark bobcat 642 that has a pretty bad gas leak coming from what looks to be either the 90 degree elbow that comes out of the carb or the hose itself right next to the carb. My question is how to I remove the carb to fix either/both to stop the leak? All help is greatly appreciated and thanks in advance Ed...
I almost forgot guys, it has the ford 4 cylinder engine in it, thanks again Ed.
I would just replace the line alot of times they just dry and crack there if there is some slack on the hose you could just pull it off and cut off the bad and put it back on
