Bridgebuilder..... pulled the tank. Had three electrical wires corroded off inside the two multi plugs we had to take off to the tank loose. It wouldn't come without moving that piece of iron between the hydraulic tank and the fuel tank. Anyway...... let's start Vegas odds on how much crap was in the tank...... almost covered the bottom of a five gallon white plastic bucket. Glad we left the fuel in the tank, fought it with ten gallons...but it cleaned out the fuel tank just fine. 1/8 cup or so of crap.
The two filters were plugged tight, had to fire up the air compressor and clean them. One, the suction side, has a check valve, the return line has just a screen. I'm going to cut the NEW plastic fuel line so it hangs an inch off the bottom. The return line will touch bottom.
Thanks for the suggestion!! Wife will be back with hose in an hour or so, we'll be back up by tomorrow, after jumpering around the broken wire connections.
God bless,
Mike Rock
