R riley012 New member Joined Mar 15, 2023 Messages 4 Mar 15, 2023 #1 Newbee here. A friend has a 1996 742B, I believe the fuel pump is shot. Is it possible to bypass this pump and install a electric pump? It is gas powered .Thanks for any help!
brdgbldr Well-known member Skid Steer Supporter Joined Jun 1, 2012 Messages 1,531 Location Oregon, (USA) Mar 15, 2023 #2 It should not be a problem. Just make sure you have the proper pressure. Should be between 3.7-5.7 PSI.
OP OP R riley012 New member Joined Mar 15, 2023 Messages 4 Mar 15, 2023 #4 brdgbldr said: It should not be a problem. Just make sure you have the proper pressure. Should be between 3.7-5.7 PSI. Click to expand... Thank you
