Fuel pick up
sparkyjr
Hello , T320
sorta pulling my hair out!
Flat squeeze bulb ….must meant fuel pick up screen is clogged? Yes ?
Is there way to access this , so I can replace it
So for I can’t even trace where to find it ?
Help 🙏
Thank you ! Now I can see both the pick up and the return, I was able to pull the tube and fitting closest to the passenger side ( this one turned out to be the return 😢
The pick up must be the one I can reach yet …..it looks like maybe a better way to reach it?
I ordered another bushing and fitting because I think I damaged the return one.
The main thing is that you helped me find them!
Any more advise is appreciated!
Thanks S
The line between the primer bulb and tank pickup fitting maybe pinched or blocked.
