Fuel gauge resistence values
Mikefromcny
Hi all, On my 873 the fuel gauge is acting up again. Reads right around full no matter how much is in the tank. Sender was replaced a year ago. At full I'm getting .33 ohms, half .082 ohms and empty .243 ohms. This is with the sender out of the tank and a multi meter applied to the 2 contacts. Does this seem like a good reading or is my sender dead again? I double checked those values, they are correct. Fuel gauge was working fine this summer into fall. I was getting pretty impressed running it a lot and plowing snow that I wasn't using any fuel! Thanks for the help.
Those readings look fishy too me. It should be a span from low res to high res........Yours at mid range look off. Those gauges are extremely fussy, the ground is very important. Before replacing, try running a temp ground wire from battery direct to sender unit, and try again. If the readings are still out of whack, yes it is the sender unit. Bruce
