I think I am down to the last broken thing on the instrument cluster. The tank is full, gauge shows empty. The fuel gauge itself was replaced. It does slightly move when the key is turned on. With everything connected, I get 00 ohms at the sender which is what I would expect. I am going to remove both wires at the sender, measure again, put some dielectric grease on things and measure with wires not attached. Then measure at the gauge. I have a hard time believing a wire is broken in the harness. Am I missing anything? What chance the new gauge is broken? I can connect the sender lug to ground and see what happens. Should read full. But sometimes that really bangs the pointer. The old gauge had saw dust inside and the pointer could move or not move or stay.
