Other Brand Skidsteer Forums
Case Skidsteer Forum
Frame Assy (Coupling System) Replacement 404599A5
Reply to thread
Message
<blockquote data-quote="jerry" data-source="post: 85806" data-attributes="member: 931"><p>Can you post a picture of the tilt linkage? Does yours have the linkage up on the boom arms instead of having the tilt cylinders directly attached to the quick attach plate? There are few bushings on these things that cant be replaced without the frame being replaced but if you have it done in a shop it wont be cheap. Reseal the cylinders , replace any bushings you can easily and see if you can live with the worn ones.</p></blockquote><p></p>
[QUOTE="jerry, post: 85806, member: 931"] Can you post a picture of the tilt linkage? Does yours have the linkage up on the boom arms instead of having the tilt cylinders directly attached to the quick attach plate? There are few bushings on these things that cant be replaced without the frame being replaced but if you have it done in a shop it wont be cheap. Reseal the cylinders , replace any bushings you can easily and see if you can live with the worn ones. [/QUOTE]
Verification
Post reply
