Forestry Door Safety switch
lewmt
I have a Bobcat T300 and just got a used forestry mulcher for it. The door safety switch had been disabled a long time ago but the mulcher will not start without it or finding a way to bypass the switch on the mulcher. The hydraulic pressure guage doesn't register any pressure and the drum doesn't turn. Bobcat doesn't have any of these wiring harnesses in stock(I've checked). Is there a way to bypass the sensor or switch on the mulcher that tells it not to operate? If I pull the wire connection at each solenoid on the mulcher valve which drives the motor - I do get hydraulic pressure but the cutter head barely turns. I'm the only operator and would never operate this mulcher without the door being shut tight so I'm not worried about the function of the sensor - I just have work that needs to get done & Bobcat has not indicated any time in the near future when I might be able to get the harness I need. I appreciate any help with this!
