For Z3CI Lx 565 question
skidsteer.ca
You posted the following
2/3/2011 7:02:40 AM (Total replies: 0)
Hi, I am new to this forum and would appreciate some help to resolve my problems. I have a LX565 and the first problem is when it is on the right side wheels turn even with out touching the lever. The second problem is that when it is parked and turned off on even a small hill it will slowly move back by it self. It releases the wheels for a second then stops and keeps on doing that. Thanks in advance
Welcome to the forum.
Aparently if you don't give the post a “subject“ then there is no link for reponders to click on to see what you asked, so I started a new thread for you.
The rolling in perfectly normal, my LS 160 has done that since I bought it at 400 hrs. Thats why it has a hand brake. Or at least the 160 does.
The other problem is your “neutral adjustment“ needs to be reset. This is a common wear issue on all skidsteer and some fiddling with wrenches in had should cure it or if you have 3000 plus hours it many need $200 to $300 (guessing) worth of parts.
Here is a link to the NH LS160 LS170 service manual, but it is the same as your loader and the info on setting neutral is in there.
http://www.mediafire.com/?ov9zqt7xwtl
