Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Foamy hydraulic oil, want to add 10w-30?
Reply to thread
Message
<blockquote data-quote="bdryer" data-source="post: 33355" data-attributes="member: 3337"><p>Been looking for leaks but have not found any yet. I found a hose that had a bad worn spot on it so i replaced it thinking it was the problem. $70 dollars for hose and didnt do a damn thing. worked on it today for a while and noticed something that might be an indicator of the problem. I checked the oil level in the tank and it was right were it was supposed to be, started it up and let it idle for a couple on minutes, could not see the oil level any more so i stuck a 3' hose down the tank to check the level and found the oil to be foamy. i didnt do anything but start the engine. What does that tell me?????</p></blockquote><p></p>
[QUOTE="bdryer, post: 33355, member: 3337"] Been looking for leaks but have not found any yet. I found a hose that had a bad worn spot on it so i replaced it thinking it was the problem. $70 dollars for hose and didnt do a damn thing. worked on it today for a while and noticed something that might be an indicator of the problem. I checked the oil level in the tank and it was right were it was supposed to be, started it up and let it idle for a couple on minutes, could not see the oil level any more so i stuck a 3' hose down the tank to check the level and found the oil to be foamy. i didnt do anything but start the engine. What does that tell me????? [/QUOTE]
Verification
Post reply
