Bobcat Skidsteer Forums
Fire on T 250
Reply to thread
Message
<blockquote data-quote="Fishfiles" data-source="post: 19846" data-attributes="member: 782"><p>When using a Fecon attachment you needed to lift the cab fairly often and clear out the leaves and debree out of the blower area , I would guess that debree built up under the blower box and the exhaust / turbo lite it up , pretty common event , dry pine needles are a killer , you mentioned adding hydraulic oil ? , maybe you had a leak which was wetting the debree with oil and the turbo lite it up --------sounds like you got it out pretty quick , you were lucky cause they usually burn up really good , probally the blower box is melted and the wiring harness going up behind the cab ,as far as moving it back to the shop it sounds rough from you discription , probally going to have to fix it where it's at</p></blockquote><p></p>
[QUOTE="Fishfiles, post: 19846, member: 782"] When using a Fecon attachment you needed to lift the cab fairly often and clear out the leaves and debree out of the blower area , I would guess that debree built up under the blower box and the exhaust / turbo lite it up , pretty common event , dry pine needles are a killer , you mentioned adding hydraulic oil ? , maybe you had a leak which was wetting the debree with oil and the turbo lite it up --------sounds like you got it out pretty quick , you were lucky cause they usually burn up really good , probally the blower box is melted and the wiring harness going up behind the cab ,as far as moving it back to the shop it sounds rough from you discription , probally going to have to fix it where it's at [/QUOTE]
Verification
Post reply
Fire on T 250
