Few issues..................
ASV RT-30. Was running fine. Now it bogs and stall under any load ONLY after it has warmed up. I changed the Fuel/Air/ and Hydraulic filters. Did the same thing. So I had to remove the water separator (which is a gigantic PITA, and for something that should be drained after every full day of use, you would think it would be easier to get to), and it definitely needed to be replaced. Now I cannot get the thing to bleed/Prime. Used the hand bulb to fill the Seperator. Now I can't get all of the air out of the fuel filter. Tried using the bleed screw on top with the bulb and I cannot get all the air out. Is there a trick to it?
