Engine sputtered and died after running over a bump
ams2020
Hi guys, Earlier today while clearing brush, I ran over a bump and the engine started cutting out.. A moment later it died. It would start up for a second or two the first couple of tries, then it wouldn't start at all. The machine ran fine all day on the same tank of gas (more than half a tank still left). I've bled/primed the lines but it didn't help. Checked for loose wires - everything seems to be OK. It is a Caterpillar 3-cylinder (ASV track loader). Any suggestions?
Sounds like your fuel pickup may have broken off. They go hard and brittle, the bump may have made it snap inside the tank, this is only a guess though.
You said you primed it, are you getting a nice flow of fuel out the line? no bubbles?
I misspoke - I did not pull fuel lines from block, just primed with the bulb. I'm going to take a look at the fuel pickup now. If this piece has broken off, is this a generic enough part that NAPA or someone else would have in stock?
Hopefully its simply a pices of fuel hose that dangles into the tank, if so, its very easy to replace.
