Engine removal 2013 T750
twalters8336
Do I have to remove the plate that connects the engine and Hydraulic pump to get the engine out or is there a trick to this? Also is there a fulcrum point for the belt tensioner? I cant seem to take enough pressure off the belt to get it off the flywheel.
Pull the engine and the hydro as a combo. Easiest way to do it, then you can get at everything easy in the wide open.
