electrical issues?
xgiovannix12
Hello everyone I have an issue with my 763 bobcat c series machine with out the boss option. When I put might lights on my gauge panel seems to lie to me. Fuel gauge spikes up and the temp tells me the machine is running hotter then its really running. I checked and clean all the connections Found a bad terminal on the switch and replaced that. Checked the connections under the cab everything is clean and electrical greased. I checked the ground at the lights all checked good at 0 ohms . Am I missing something? I cant read my electrical diagrams on my cd manual they get really blury when ya zoom em here is a video of my issue https://www.youtube.com/watch?v=c_9gvexnwzY
I would check the connection for the lights. Especially the grounds. It sounds like it’s looking for a ground
ill try that you gave me another idea as well... I do not have the cab bolts installed right now.
Just spent a whole day chasing electrical problems on a truck. Everything from gauges to no charging to lights flickering. Turned out to be a bad cab ground
