I turned around to the bobcat smoking and electrical harness melting together. A older 753L I spliced all the wires back together, replaced a relay and hunted around trying to find blown fuses and otherwise diagnose. When I turn the key I get nothing no starter solenoid sounds, nothing on boss display, no beeping no headlights just dead. I checked starter for power and am trying to understand the fuel shutdown solenoid and timer which doesn't engage and pull pump off stop. What can I troubleshoot? Can i bypass anything to show some life? Should I change other relays? Are there other fuses i am not seeing? It is a older c series I believe, rectangular headlights and has been bulletproof. Guys if you have some more steps to take please inform
