Bobcat Skidsteer Forums
Electric fuel pump function.
Reply to thread
Message
<blockquote data-quote="davim" data-source="post: 103702" data-attributes="member: 16131"><p>Aloha Rodger, I have a similar issue,, its hot here and the mechanical fuel pump vapor locks, want to install an electric, plan to use pressure reducer, question ? best place to locate the electric fuel pump,( it gets pretty warm around the engine and its cowlings and do i need a bleeder valve past pump back to tank to allow pump to prime? any suggestions would be of great help,, im in the dark over here....Mahalo for your time,,, davim@hawaii.rr.com ps what is a pump bulb? similar to what is used on small boat motors?</p></blockquote><p></p>
[QUOTE="davim, post: 103702, member: 16131"] Aloha Rodger, I have a similar issue,, its hot here and the mechanical fuel pump vapor locks, want to install an electric, plan to use pressure reducer, question ? best place to locate the electric fuel pump,( it gets pretty warm around the engine and its cowlings and do i need a bleeder valve past pump back to tank to allow pump to prime? any suggestions would be of great help,, im in the dark over here....Mahalo for your time,,, davim@hawaii.rr.com ps what is a pump bulb? similar to what is used on small boat motors? [/QUOTE]
Verification
Post reply
