corporal32
- Joined
- Jan 27, 2016
- Messages
- 9
Hi all,Does anyone know how to check the ECL sensor on a 753,thanks for any help
i checked the level first,will order the sensor next,thanks for the inputyea check coolant level . if its full replace sender.. 99 1/2 times problem solved.
i just got my sensor today and put it in,im a little confused,when i turn my key to the right i get four different alarms,ecl1,hf1 2,fuel3,af6..once i start it the only alarm that shows up is the fuel3,not sure why it does this and if there is a way to reset them like you used to do in a car by pulling the negative side off the battery or if the replacement sensor wasnt the problem.looking at the schematic it looks like its wired straight to the computer with no relays or fuses in the circuit.yea check coolant level . if its full replace sender.. 99 1/2 times problem solved.
