ECL-1 Shutdown and BOSS Pinouts.
MrBobcat753
Looking to diagnose fault on 753 with BOSS Unit. Do not have diagnostic tool. Have swapped out ECL Sensor and checked continuity. Anyone have BOSS diagram to have to hand with the correct Output Voltage from the BOSS to the Coolant Level Sensor? Currently 0.15V which seems low. I have seen service manual with values for other engine sensors but the Coolant one isn't given.
Forget that its probably capacitative.
7LBSSMALLIE - recommended in another thread to check and clean the cab ground connection.
The ECL sensor relies on a good ground connection.
I looked through all my Service Manuals and did not find any information on the operation or testing of the ECL sensor.
Engine coolant sensor is a variable resistor that changes its resistance depending on the temperature. Tonight I can check at what degrees how much ohm should be.
I apologize, I have confused this sensor with the temperature sensor
