Mikefromcny
- Joined
- Nov 13, 2011
- Messages
- 352
The 873 has a horn on the front, what button makes it work?
Fixed. Was kinda warm out today (34F) so Thought Id mess with it. Turns out it is a factory horn. The plunger for the button on the left stick which I kinda thought was the horn was stuck down. I pulled the handle apart, cleaned everything up, fixed the power wire and added a ground for the horn. Its loud! Should be great for scaring friends and letting drivers know when theyre too close when heading down the road. Thanks sstec.If it was a bobcat horn kit it should be on the left handle.
Check with OM for instructions 6720761 it will show you the parts, harness and instructions.
If it's not a bobcat horn kit, then follow the wires is all you can do. . . .
sstec
