I have a 1988 642b and i just had the pump rebuilt. After installing the pump and filling the system with fluid I took it for a test drive. Everything was fine until I made my third turn and headed back to the shop. About half way there the left side seemed to lose alot of power. Now I have no reverse on the left side and forward feels weak. I have swapped the replenishing valves and it made no difference. I had the left drive motor rebuilt and it made no difference. With the loader lifted and block I get drive in both directions on both sides. When it is on the ground I have no reverse on the left side. Now, if I lift and block the loader I can not turn the wheels by hand on the right side. On the left side I can turn the wheels forward by hand easily but reverse by hand is difficult. I don't believe I should be able to turn these wheels at all by hand with the loader turned off, Correct? Anyway, I don't know where to go from here. I don't want to pull that pump again. Any ideas or in put would be great. Thanks
