Bobcat Skidsteer Forums
Drive motor sprocket
Reply to thread
Message
<blockquote data-quote="waggles" data-source="post: 46790" data-attributes="member: 3105"><p>I think the drive sprocket is a machined part of the shaft, the brake disc sits on the end of that shaft. The sprocket shaft goes into the reduction gearbox and the Hydraulic drivemotor in turn drives the gearbox. Two separate parts that bolt together. You could leave the brake disc's off but then you have no park brake.</p></blockquote><p></p>
[QUOTE="waggles, post: 46790, member: 3105"] I think the drive sprocket is a machined part of the shaft, the brake disc sits on the end of that shaft. The sprocket shaft goes into the reduction gearbox and the Hydraulic drivemotor in turn drives the gearbox. Two separate parts that bolt together. You could leave the brake disc's off but then you have no park brake. [/QUOTE]
Verification
Post reply
