Bobcat Skidsteer Forums
drive motor issues
Reply to thread
Message
<blockquote data-quote="thatdamnabe" data-source="post: 52002" data-attributes="member: 6937"><p>Looked in my hydraulic tank and found it looked milky white. Upon further inspection i noticed it is air bubbles. Started with the port block filter and found what appears to be a screwdriver hole punched through the back of it. Had to order a new filter should be in in a few days. Bobcat mechanic here is super helpful as long as his boss isn't around. He said that the puncture hole could be agitating the oil and causing the problem. He also said to check the return lines for a loose fitting. But didn't specify what lines these are? Thought I could figure it out so didn't ask, wish I would have. How does this diagnosis sound to you guys?</p></blockquote><p></p>
[QUOTE="thatdamnabe, post: 52002, member: 6937"] Looked in my hydraulic tank and found it looked milky white. Upon further inspection i noticed it is air bubbles. Started with the port block filter and found what appears to be a screwdriver hole punched through the back of it. Had to order a new filter should be in in a few days. Bobcat mechanic here is super helpful as long as his boss isn't around. He said that the puncture hole could be agitating the oil and causing the problem. He also said to check the return lines for a loose fitting. But didn't specify what lines these are? Thought I could figure it out so didn't ask, wish I would have. How does this diagnosis sound to you guys? [/QUOTE]
Verification
Post reply
drive motor issues
