drive chains
adsmith72
Anybody ever use the import chains? I was thinking of using a 60H drive chain from farmex. I know the diamond chain would be better, but this is and old 520 that gets limited use. will it last at all or will it stretch really fast or break?
On a small machine, i can't see a big problem. They should all be made to the same specs so they shouldn't stretch or break. I thought the H meant it was for heavy machines anyway? so it should be more than strong enough.
I installed new bearings and chain in a 453, there were no problems, i haven't given it a lot of use since, so i can't say how long the chain lasts. It was cheap chinese chain, but i was told it was a good quality still (its a guy we know personally).
Good luck with the repair.
Yes the H does mean heavy duty. I measured the import chain and even the heavy duty is a tiny bit thinner than the diamond chain. I know diamond pre stretches their chains so you don't get that intial quick stretch when you put it on. Is the (import) farmex pre stretched?
