Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Draining the gear boxes
Reply to thread
Message
<blockquote data-quote="Mike10" data-source="post: 64696" data-attributes="member: 5461"><p>Just rock the wheel back and forth and see how far it moves. If you are tightened out and you still have excess rocking then it may be time for chains. If they are not so loose that the chain slaps the bottom of the case I would run them. If there is enough adjustment then I would just make sure the axle itself can rock back and forth slightly without the wheel on. With the side covers off you can tell if the chains are too tight or too loose. I like to see a little slack in the chains rather than fiddle string tight.</p></blockquote><p></p>
[QUOTE="Mike10, post: 64696, member: 5461"] Just rock the wheel back and forth and see how far it moves. If you are tightened out and you still have excess rocking then it may be time for chains. If they are not so loose that the chain slaps the bottom of the case I would run them. If there is enough adjustment then I would just make sure the axle itself can rock back and forth slightly without the wheel on. With the side covers off you can tell if the chains are too tight or too loose. I like to see a little slack in the chains rather than fiddle string tight. [/QUOTE]
Verification
Post reply
