Draining Hydraulic Fluid-630
ancomcabs
Manual says remove the filter then disconnect the hose to drain the fluid, not very specific, two hoses up there plus they are up high I imagine they would have to be routed down low to drain the fluid. Is this really the only way? Seems like there must be a better way
The way i do it is to run the machine at idle and pump it out of the quick couplers. If you can find a hose down low, you can crack it open and it will drain, but it may take a while.
There is no easy way to do it sadly.
