General Skidsteer & Technical Topics
Shop Talk
Diesel Engine Idling
Reply to thread
Message
<blockquote data-quote="Kanman" data-source="post: 83476" data-attributes="member: 11876"><p>Although much idling is a pure waste of fuel. It's not doing as much harm as some of these posts would lead you to believe. Diesel engines no longer "wash down/wet stacking" the cylinders like they used to. Most engines these days have an ECM controlling pulse width, timing and sensors. Where as the older pump controlled motors had no such advantage. One thing is for sure. Every time a crankshaft goes around, that's 1 less time it will ever do so.</p></blockquote><p></p>
[QUOTE="Kanman, post: 83476, member: 11876"] Although much idling is a pure waste of fuel. It's not doing as much harm as some of these posts would lead you to believe. Diesel engines no longer "wash down/wet stacking" the cylinders like they used to. Most engines these days have an ECM controlling pulse width, timing and sensors. Where as the older pump controlled motors had no such advantage. One thing is for sure. Every time a crankshaft goes around, that's 1 less time it will ever do so. [/QUOTE]
Verification
Post reply
Shop Talk
