Hello to all: I've got a 2000 Cat 226 skid steer and the engine cranks but wont start.I pulled the fuel solenoid out and it starts right up. I then installed a new solenoid and it dosen't start. Fuses are good,I swapped around the 3 relays on the fuse panel and still nothing. Not sure where to go from here. Also I ran the machine for a couple of hrs with the fuel solenoid pulled out and noticed when I had to reinstall it I had oil sprayed on the engine. Am I loosing oil pressure and damaging the engine by doing that?? Did I it screw up?? When I go to acc with the key the white wire is hot,when I turn the key to the start position the red wire goes hot. Pull back and hold. Thank You Kindly Greg
