Deere 675b safety lock out on hydros its not the seat switch
Fselegacy
I just picked up this unit and have been running it 20 hrs a weekend since I was running it yesterday as I was coming in to pickup another pile I lost hydros I noticed my seat light and seat belt lights weren't on i shut it off got out of the seat sat back down put my seat belt back on no lights no start so I pushed the switch to service and the start light came on the the box and the engine started..... to sum it up I have no lights on the control module unless it is in service mode and I'm starting then I get a start light but no seat belt or seat lights I've checked I do have 12 volts at the seat I don't know what else to do I dont want to bypass all the safety's but I might have to
If you're getting voltage at the seat sensors, you're probably not getting signal to the box. Best thing to do is start disconnecting connectors and give them a shot of contact cleaner (or at least WD40).
Chances are one has some corrosion that is screwing up the reading. Unless you are systematic and do one at a time it will just start working without knowing the solution. Depends on the time you have to spend on it; it's more time effective to service a bunch of connectors at once and get it going and pour over the wiring schematics later to determine what fixed it.
Ok I'll give that try when I get home I'm really hoping that stupid grey box isnt fried John deere wants 1200 for a new one ... would anyone happen to have a decent wiring schematic
Wd40 did the trick thank you ! it's always the simplest things
Which connections did you disconnect and clean? Where the lights are? I am having the same issue.
My seat belt light will go off when I latch the seat belt. It might stay off all day or you might go 20 feet and it ll come on and won’t let you use the loader. I put a new seat belt in. I took out the box on the right pillar and cleaned the connection to the seat belt light connections. Still having random issues.
