I picked up a Davis D100 that seemed to be retrofitted to a Bobcat. It utilized the trailer style coupling method, but it was all beat up so I made my own. It was hacked together when I got it and someone branded it with Bobcat logos.
I took the pushbeam from an old Fisher snow plow and cut the framework on the backhoe so that when the bucket cylinder curled all the way back the backhoe seat would be level. I had to lengthen the push beam so the ears lined up where I wanted them.
I then took the brackets that came with my backhoe and cut the ball off and welded 1/4” plate that I drilled with a 1” hole that would line up with the 1” hole on the push beam.
To beef everything up I used a piece of 1/4” diamond plate and covered the top surface of the framework. This provides for a small platform where I might put a spill kit or a cooler.
This setup needs a little tweaking but its better than the trailer coupler method. Many here suggest using tractor 3pt links, but I had all this material around and its the same concept minus the adjustability aspect.
The backhoe works well and will dig down at least 6 feet.
That rock is about a 1/3 of a yard and picked it right out.
My main problem now is the seals on the boom and bucket cylinders leak after I take it off my Bobcat and let it sit. They do not leak while connected to the Bobcat. I believe the boom cylinder leaks about 8oz everytime. I have a local guy that will install the seals, but I need to get the seals before he will do the work. The pistons are Lantex brand and the bucket cylinder is marked 847C. JD8875 has replaced the seals on his backhoe and I am waiting to hear back from him in regards to the part numbers he purchased. The boom cylinder has a different packing nut that the bucket cylinder.
I understand how to disassemble the bucket cylinder to measure the seals if I have to, but I don't know how to disassemble the boom cylinder. I tried tightening the nut, but it just spun. After I tightened the cap it didn't leak as bad, but it still leaks. Any ideas would be greatly appreciated.
The bucket piston cap looks like this.
Where the boom cylinder cap looks like this:
