D7517 error. 2018 s595
S595owner
Machine is like new... personal use. 167 hours
Ofcourse it's just out of warranty lol
Machine has always worked perfect. Only hiccup so far has been a failing battery. I've had to jump it the last couple times I used it. The last time it was used was about 2 weeks ago.
Today I had to move some stone. I had to jump it. When I turned the knob to start it, it fired right up, no problem.
As soon as I hit the green button, the machine throws a "D7517 left swashplate not in neutral" error.
Any advice?
If it's got hand/foot controls, make sure the left stick is free and fully returning to neutral. May need to lift cab and check/adjust the linkage.
If it's SJC controls, then you might need to recalibrate the servo.
Or it could just be a bad swashplate sensor/wires.
If the battery is bad enough, even though machine is running, it can cause electrical/electronics issues. Not the first time simply replacing a bad battery has solved electrical gremlins.
