D125
Jody
I own a d125 that works very well other then a sudden drop in the main boom as your your pulling back. It only does this if your going slow. i'm gathering i need a o-ring kit for the spools? I'm having a hard time getting info on this. Can someone please help? Thanks
It does sound like the load checks may be leaking internally. They should be screwed into the control block as you said. Some had metal on metal poppets, sone used O rings, i don't know what your machine uses though.
