Other Brand Skidsteer Forums
John Deere Skidsteer Forum
CT332 Final drive Cover plate removal??? Please Help!
Reply to thread
Message
<blockquote data-quote="bucketboy" data-source="post: 90447" data-attributes="member: 12904"><p>DeereFan, I recently removed mine by unscrewing the hex bolts part way out and then using a pair needle nose to gently pry it off. Also, I found it helpful to tap all around the cover with hammer to loosen the plate. Keep in mind when you do get it off, you will need some heavy silicone to hold the o ring in place to get it put back together if the drive is still on the machine and not setting on a work bench. Hope this helps.</p></blockquote><p></p>
[QUOTE="bucketboy, post: 90447, member: 12904"] DeereFan, I recently removed mine by unscrewing the hex bolts part way out and then using a pair needle nose to gently pry it off. Also, I found it helpful to tap all around the cover with hammer to loosen the plate. Keep in mind when you do get it off, you will need some heavy silicone to hold the o ring in place to get it put back together if the drive is still on the machine and not setting on a work bench. Hope this helps. [/QUOTE]
Verification
Post reply
