Other Brand Skidsteer Forums
John Deere Skidsteer Forum
CT322 Engine (4024T)
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 59479" data-attributes="member: 7339"><p>No they can not be reused, they are torque to yeild bolts. Be very carfull when installing the head to get the front coolant gasket in the right place. It will really piss you off if it leaks and you also have to take the head. Also I would recommand finding somebody who works on these engines. It takes a skilled hand following the exact steps to a tee to set injector pump timing.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 59479, member: 7339"] No they can not be reused, they are torque to yeild bolts. Be very carfull when installing the head to get the front coolant gasket in the right place. It will really piss you off if it leaks and you also have to take the head. Also I would recommand finding somebody who works on these engines. It takes a skilled hand following the exact steps to a tee to set injector pump timing. [/QUOTE]
Verification
Post reply
