Bobcat Skidsteer Forums
Cracked lift arms
Reply to thread
Message
<blockquote data-quote="Filthy58" data-source="post: 54111" data-attributes="member: 7272"><p>I'm thinking the most likely culprit is using the auger attachment over to one side instead of in the middle. Especially since most of the augering I do requires getting the machine up on one or no wheels, the tie down point at the rear, and with the rest of the weight on the auger. Kind of obvious when you think about it. Not quite how Melroe envisaged it being used I'll warrant. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="Filthy58, post: 54111, member: 7272"] I'm thinking the most likely culprit is using the auger attachment over to one side instead of in the middle. Especially since most of the augering I do requires getting the machine up on one or no wheels, the tie down point at the rear, and with the rest of the weight on the auger. Kind of obvious when you think about it. Not quite how Melroe envisaged it being used I'll warrant. :) [/QUOTE]
Verification
Post reply
Cracked lift arms
