This is my first post but I've been reading for awhile. I just used some advice here to replace the fuel pickup tube on my 763. By the way, if you do replace the pickup tube, replace the bushing/grommet.
I kept trying to get the original back in and it wouldn't go. I guess it just hardened over time because I bought the new bushing and it was much softer and popped in much easier (not easy, but only took a few minutes).
Anyway, I am no where close to a mechanic. I work on computers for a living and have a little land that I've been working on myself so a year ago I bought a used 763 with a trailer for $7500. Has about 3700 hours on it.
Everything was working great for the last 11 months or so and now I've run into some problems. I had a hydraulic leak that started up a month or two ago. Tracked it down to a control valve and decided not to attempt the job myself.
Found a guy here that did for me for a very fair price. Everything seemed ok with that. Seems to pull a little more one way now than it did before but no leak.
I then decided to take my machine into the bobcat dealer and get some maintenance done. I got the oil changed, replaced the hydraulic fluid because it wasn't bobcat fluid, changed two belts, programmed the computer because it was throwing a generic code which indicating programming needed. $900 later and I feel like the machine is louder and I have the following issues: -
When I lower the bucket (not tilt) it goes very slow but seems to have full power just very slow. Something just feels odd with the pedal but it could just be because the bucket is going so slow and I never had to pay attention to it before. Everything else (raising and tilting) is fine. -
The emergency brake is not working. The first I found out about this was at the bobcat dealership. I thought it worked ok before but did occasionally notice some issues with it.
Every so often I'd have to either specifically back up or go forward after turning off the brake to get it to move the other direction. A couple times I accidentally forgot to take off the brake and started to go and it didn't sound good but would move a little. Now it doesn't work at all. -
There also seems to be a loose chain sound sometimes when the bucket is all the way down and I drive. I move it up a little and the sound goes away. I would appreciate any advice on dealing with these issues. Thank you in advance for your time.
