elbowcarey
- Joined
- Feb 3, 2012
- Messages
- 84
Hey guys I have another ? 543 with slow hydralics, everything works just slower then it should be and the light comes on and off. So I checked and the control valve seems to be leaking so I ordered a seal kit to rebuild since it was only $100. I have not run it hard or for more then a few minutes since I bought it and replaced the left side drive. The pump has never been hot to the touch after running it and no leaks on the pump itself. I must have low charge pressure but how do I know what to work on first to fix this problem, I picked the rebuild kit because it was cheap and its leaking anyway. Also I seen in the manual that you can adjust the relief valve clockwise to increase pressure is this a good idea to try or will it just make it out of adjustment once I rebuild the control unit? Any help would be great
