This is where I am at now. Pulled solenoid again, made up set of jumpers to attach to plug on solenoid. Hooked ground to neg post of good battery, touched pull wire to pos post, solenoid picked up, touched hold wire to post, removed pull wire, solenoid held. Repeated a few times, solenoid worked fine. Hooked up jumpers to plug under seat .Sat in seat with solenoid in my lap, dropped seat bar,solenoid no work. Metered wires as I played with the seat bar. 13.3V on hold wire, .125 on pull wire. Looks like pull coil not getting enough voltage to pickup. Metered relay, 14.4V on line side of relay, waiting to go to pull coil , only 8.5 from BICS to relay. I don't think that is enough to close relay. Looking at wiring diagram, BCIS tells relay to close, sending juice to pull coil of solenoid. Voltage for hold coil comes directly from BCIS. Pondering how I checked voltage at relay, I wasn't in the seat with seat bar down. Wonder if that makes a difference? If it did, I would think there would not be any voltage from BCIS to realay at all, but I have 8.5. Any thoughts about all this? Where do I go from here?
