Compact Skid Steer Hydrolic Gear Pump
Steve1600cc
So this thing is a pain.. 2 years now only issue constant... Pump floats essentially the lines hold it from moving alot which of course if not isolated will rub against something and Break... Then you think make a mount or do whatever to firmly hold in place.. Well then the shaft breaks.
Best so far is some 90 metal elbows that swivel taking out some of the Vibration and a Red rubber piece buffering it from spinning or swilvlong to much... Only one guy on Utube with this issue and was not really a solve.
Any help would be greatly appreciated... Is there a 12 volt pump could do this with and a toggle switch?
This pump is for the up and down of bucket and curl by the way... I tried this Muffkee Bracket but that broke the Shaft also..
content edited away, accidental double post.
moderator, please remove this post?
