Bobcat Skidsteer Forums
cold weather by - pass valve
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 39066" data-attributes="member: 82"><p>It just seems odd. The fluid to the drive pumps is the only thing that could stall the engine. The hydraulic pump is small enough to not be able to stall the engine.</p><p>You mentioned the engine was just rebuilt, are you sure the govenor is functioning as it should? the engine should have more than enough power to not stall with such a small load. You should be able to drive it at full speed without an issue, but you will need to back off a little when digging.</p></blockquote><p></p>
[QUOTE="Tazza, post: 39066, member: 82"] It just seems odd. The fluid to the drive pumps is the only thing that could stall the engine. The hydraulic pump is small enough to not be able to stall the engine. You mentioned the engine was just rebuilt, are you sure the govenor is functioning as it should? the engine should have more than enough power to not stall with such a small load. You should be able to drive it at full speed without an issue, but you will need to back off a little when digging. [/QUOTE]
Verification
Post reply
