code 13-06 on s-185
flo
Is there anyway to bypass the shuttoff solenoid? Where would it be located? Am stuck on a job and dealer is closed for the holiday. Help!
unscrew the two 3/16 allen headed bolts that hold the solinoid to the block , tie strap the wiring of the solinoid so that it will hang freely , you can start it up and run it , it ain't going to kill with the key or key pad so to kill it you will have to stick your finger or a screwdriver or something into the hole and push the arm down , oil is going to splash a little out the hole and dirt could get in so you have to come up with a way to plug off the hole if you are going to run it for an extended period if you are just going to move it or put it on a trailer then leave it open , you can clean the area around the hole the solinoid came out of so that duct tape will stick and cover the hole -------in this state it will not shut down if pressure is lost or temperature gets up but you will still get a warning , the kill code will still flash but it will run
