Bobcat Skidsteer Forums
Cleaning
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 47339" data-attributes="member: 82"><p>You sure can, just try and keep the high pressure water off the connectors. If you tilt the machine forward and backward depending on where you are washing it helps get the water out so you can get a better clean.</p></blockquote><p></p>
[QUOTE="Tazza, post: 47339, member: 82"] You sure can, just try and keep the high pressure water off the connectors. If you tilt the machine forward and backward depending on where you are washing it helps get the water out so you can get a better clean. [/QUOTE]
Verification
Post reply
Cleaning
