CL 55
Scouterwillie
New to the site I recently acquired a CL 55 skid steer that had been left in the bush fir 6-8 years. With a new battery the Shibaura motor started and ran fine We moved it to the shop and want to change filters and oils before I do any thing else Where can I find specs and quantity of oils needed
Moved to the NH forum in hopes that someone will have the info since they took over the Ford line.
Thanks for the info The site has all the answers Because the machine sat so long I want to drain old fuel and oils before I run it Looks like all the filters are available
Need to drain the hydraulic tank and replace filers on the Ford CL 55 skid steer wondering if I should use 10/30 motor oil or 46 weight hydraulic fluid. system has air in
