charge pressure
digsalot
Decided to check the charge pressure on my 753. Book says 200. Gauge says 110 at idle and 170 full throttle. Oil level is correct. Not sure of location of relief valve. Going to pull hydrostatic drive out and tear it apart. Other issues besides the low pressure. Anything special I should look for. Bottom red light on dash lights up at full throttle also. Think its the trans light. Symbols long gone. Thanks
The relief vavle should be on the backside of the hydro, the engine side. Should be adjustable by shims. If adjusting it up doesn't bring it up, have the gear pump tested. Small chance the drive belt is the issue. How do the functions operate?
Bucket functions are good. Pressure at the auxiliary hookup are between 2500 to 3000. Drive functions not so good.
