Changing Hydraulic Fluid
Tommyboy
I have a 2000 753 G Series. What is the best way to drain the hydraulic fluid? Just pump it out? Is there an actual drain plug? I cannot seem to find one. There are small filters in the lines that need changed-should it be drained there? Also, I watched you tube and noticed when they remove the large main filter in the back engine compartment some guys start it up for a few seconds to get more fluid out??
