Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Changing hyd fluid
Reply to thread
Message
<blockquote data-quote="Mike10" data-source="post: 50433" data-attributes="member: 5461"><p>On the LS180 you can remove the small plate which gives you access to the engine oil drain plug. If you look to the right of the drain plug you will see several 3/4" lines going into a rectangular block. Disconnect one of these lines to drain the hydraulic oil.</p></blockquote><p></p>
[QUOTE="Mike10, post: 50433, member: 5461"] On the LS180 you can remove the small plate which gives you access to the engine oil drain plug. If you look to the right of the drain plug you will see several 3/4” lines going into a rectangular block. Disconnect one of these lines to drain the hydraulic oil. [/QUOTE]
Verification
Post reply
Changing hyd fluid
